Solved
Ordered Parts, Need Problems I Might Encounter. 1st Build.
  • Build
  • Cooler Master
  • Systems
  • Product
Last response: in Systems
August 22, 2011 12:14:56 AM
Heres my build.
Cooler master haf 912 - $55 - http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Asrock AM3+ MB - $105 - http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Sapphire 6950 - $240 - http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Antec EarthWatts EA-650/w cord- $60 - http://www.newegg.com/Product/Product.aspx?Item=N82E168...
G.SKILL Ripjaws X Series 8GB - $40 - http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Hyper 212+ - $27 - http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Seagate Barracuda /w Asus Cd/Dvd - $68 - http://www.newegg.com/Product/ComboDealDetails.aspx?Ite...
AMD Phenom II X6 1090T w/ Dues Ex - $160 - http://www.newegg.com/Product/ComboDealDetails.aspx?Ite...
I have $56 worth of combos and $46 worth of promos.
Total Price Without Mail in Rebate - $755
What issues might I run into with this build?
More about : ordered parts problems encounter 1st build
Best solution
August 22, 2011 12:18:37 AM
The time to ask questions is BEFORE you order, not after.
For example, I might have warned you that a X6 is a poor gaming cpu.
Never the less, take the time now to download and read, cover to cover the motherboard and case manuals.
---good luck---
August 22, 2011 12:29:27 AM
---good luck---
I know its not the best gaming cpu, but i'm only a small monitor so between it and a 6950 i think it will get the job done. Thanks for the manual advice I'll do it now.
m
l
August 22, 2011 9:57:14 AM
Best answer selected by vtphs.
m
l
August 22, 2011 7:39:06 PM
for the videocard around the 240 price range the better card to go with would have been the 560 ti.. and the phenom x6 isnt that great for gaming...
good job on getting a am3+ board though u can upgrade that with the new amd cores later as they come out
m
l
