Can My PC Handle 2 Zotac GTX 460s in SLI Help
Hello there very quick post my pc is
Windows 7 Ultimate 64 Bit Edition
Amd Phenom 2 995 Black Edition 3.2 GHZ
10Gb DDR3 10600 1333mhz
2 harddrives a standard 250Gb
2tb seagate 64mb green ediiton catch harddrive
Motherboard Asrock something i forgot proper details AM3 slot ram capacity 16Gb duel channel ram 2 x PCI Express 16X slots
1X Zotac GTX 460 768MB
Now i have another PCI Express slot here X 16 can i buy another Exact zotac GTX 460 and install it i want another graphics card as i do 1080P Video walkthroughs for youtube with fraps and i need between 50 and 100FPS
ohh my power supply is a Extreme power power cool 1050 Watt power supply i have the box and information here it says
2/4 multi RAIL Technology Multi Core CPU Support Advanced Thermal Accustic Design
8 ( 4 =4 pin =12v all models 1
4 pin molex 450 - 650w x4 750w -1050w: 5
8( 6 =2) pin PCI - E all models 2
Sata 450w -650w 4 750w 5 850w - 950 watt 6 and 1050w 7
Thats all the info on the box lol its not some cheap generic one it cost me nearly £100 on Ebay
so Tech guys is my computer capale of another Zotac GTX 460 Graphics card in duel channel also i have never installed one before any help info would be appreciated if its compatible many thanks
JOE
7 answers Last reply
More about handle zotac 460s help
  1. Edit Everything is on factory settings nothing is overclocked :-)
  2. Edit 2 i finaly found the motherboard box and it says ATI Crossfire tecknoligy :-( does that mean Nvidia Sli is not supported as its an ATI motherboard damn :-(
    Probably, and if your 1kw PSU is not able to run 2 460's then it really is a load of pants! :lol:
    I think the power supply is ok to run Nvidia sli but now im worried about my board being a ATI certified one that wont support another GTX 460 i didnt quite understand your reply mate is an ATI board capable of Nvidia sli many thanks
  5. There are a few who say that you can run a hack to make Sli run on such a board, but as I've not tried it I can neither confirm or deny whether it works or not.
  6. Right i think i will give it a pass then shame realy i realy wanted to upgrade too :-(
  7. you can up-grade your mobo to a 990FX AM3+ and run SLI but it will cost you $200 more to do so. Just a thought. Your current CPU will work in the new socket! RAMs good too
Graphics Cards Gtx Zotac Graphics
