Hi everybody well the issue is that the right usb 2.0 on the top of the case does not seem to function at all even though the left one does.I'm looking for suggestions and if anyone knows do they have seperate usb connectors or not?
If you plugged all the lead wires from the case into your motherboard then it should work... elsewise you rpobably just have a bad connector. Tough luck man
