Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > dell inspiron 1100 wont work with power adaptor.
Forum Laptops & Notebooks : General Laptops & Notebooks - dell inspiron 1100 wont work with power adaptor.
Archived from groups: comp.sys.laptops (More info?)
ok I have this dell inspiron 1100 that will work with the battery but
not with the adaptor. i tried replacing the adaptor with a brand new
one but same problem nothing will light up. and wont even charge the
battery. i tried going into the bios and check the power supply and
it detects the adaptor but says its only 50w but i know its 90w. can
someone please help. thanks.
Sponsored Links
Have you tried running it with the adaptor plugged in but with the battery
removed? A gimped battery can do funny things sometimes. If you're
positive that the adaptor is good and is 90W, this is the only thing I can
think of (other than: the ac you're plugging it into is screwed or the
good old standby: bad mainboard.) I've seen Dell notebooks complain about
low-wattage adaptors in the past, but never when they haven't indeed been
plugged into something not as strong as they need.
-dirk
Reply to Dirk
The main fuse might have opened. This can sometimes be repaired with a
fast-acting Picofuse of the appropriate rating soldered over the
existing fuse terminals. Otherwise, it is a power supply board or
mainboard replacement, depending on the design.
Q
Reply to Anonymous
how do i tes this thanks.
Reply to Anonymous
how do i test this thanks.
Reply to Anonymous
i did some more checking and with the battery removed the lights on
front of the laptop keep blinking. when i put the battery in the
lights go out but no power. there is power to the laptop through the
adaptor but it seems like theres not enough like something is
restricting it
Reply to Anonymous
restricting it
Reply to Anonymous
There are 914 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
