Hi all,
am looking at upgrading my dads work PC. currently he has a amd6000+ which is very dated obviously.
at home i recently built him an AMD x4 965, and he would like a faster machine than this for work, as he spends 80% of his computing time at work.
i dont have a budget set in mind, but i know he wont be able to afford anything like an i7 2600 (i absolutely LOVE my i7 2600k), so was thinking of some of the lower i3 / i5's
as he is a real estate agent, he often deals with large images (4mb jpeg files) he has on average 20gb of picture files and 2000+ contacts in Outlook 2010. that would be his main use.
am i thinking along the right lines of the sandybridge processors ? or would there be something else more suited to the job ? .. also considering the possibility of a small SSD (OCZ Vertex2 60gb perhaps)
from the research i have done, the AMD 965 is on par with the Intel i7 870 (1156), however majority of research i have found points towards gaming rather than business application.
so i guess my question is, would an i3 2120 (being dualcore) be enough of an 'upgrade' over an AMD965, or would he need to go to something like an i5 2300/2500 to see/feel a difference ? i am not sure if the budget would allow an i5 + SSD. so how would an i3 2120 + SSD perform vs i5 2300/2500 with 7200rpm drive.
or should i be looking at something entirely different ?
also one more quick question, would it be fair to assume that onboard graphics would perform the same in regards to opening 4mb picture files, as a dedicated graphics card?
also, 4 vs 8gb ram will need to be decided at some point too
sorry for the long poorly structured post! i appreciate any input
-ReaperZ
-ReaperZ
