Hello,
I'm looking into making a new system and I started from the $2k system marathon build.
At the moment the setup looks like this:
CPU: 2600k (+ Xigmatek Gaia SD1283 heatsink)
Memory:G.Skill F3-12800CL8D-8GBXM
Drive: F3 Spinpoint (still of the opinion the SSD's are too expensive for what they deliver)
Mobo: Asrock Z68 Extreme4
PSU: Corsair HX850W
GPU: 2x6970
Case: Haf X/FT02/Lian Li 9F (or others)
The build would be used for video rendering(3d) aswell as gaming (and multitasking). Monitor atm is at 1920x1080 and I'd probably get another (better) screen in a few months.
There are 3 things bothering me now.
1) Do I really need the crossfire for this kind of use or should I get a single card 590/580 or 6990? Whilst the 6990 is humongous I'm still skeptical of NVIDIA since my last 9800x2 got fried (eventhough they are known to like high temps).
2)I'd like a case that (like the FT02) has good air cooling, cable management and toolless drive mounting. Another issue is if 2 6970 or one of the single cards would fit (mainly the 6990) in the FT02 or the other 2 mentioned cases. By fitting I mean having some space. Another benefit of the FT02 is its low noise and dust filters (which the Haf X doesn't have).
3) Would that PSU be able to power the crossfire or other cards without too much trouble?
Thank you,
Warflesj
PSU: Corsair HX850W
GPU: 2x6970
Thank you,
Warflesj
