Solved
Power Supply Question
Hey everyone, I have an important question to ask about my new build. Will this Power Supply,
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139028
Run 8 gigs of ddr3 ram clocked at 1333, a Phenom II x4 840, a 500gb 7200 rpm hdd, and an hd 6850? I know the optical drive won't consume much power, so I didn't include it.
My case is an NZXT Gaurdian 921 rb, here's a link:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146069
It comes with 3 fans, 2 of them with leds, and a temperature module.
Thanks,
Chris
2 answers Last reply Best Answer
More about power supply question
  1. Best answer
    You're card needs a minimum off 500watts, so yes that power supply is about perfect for what you want.
  2. Best answer selected by daChRISGUY.
New Build Power Supplies Systems Product
