I have decided the components i am going to buy for my first pc build, but i have a question regarding the motherboard and the case.
The case is: Case: Cooler Master HAF 912 Plus ATX Mid Tower Case
the motherboard is: ASRock Z68 Extreme3 Gen3 ATX LGA1155 Motherboard
My question is (sorry if its stupid, i am new to this stuff and its my first time) will the motherboard fit with the case? I heard that the case doesnt have the end 3 holes in the correct place for my motherboard, so i will only be able to have the first 2 rows screwed down. If this is true, then does it matter and if it isnt, are there any other cases i should look into that are good but not too expensive?
