Motherboard help
i'm using intel pentium G630 (2.70Ghz)
i wanted to purchase new motherboard that have
1. Asus (company)
2. usb 3.0 supported
3. onboard graphics
4. price - below $100
please help
12 answers Last reply
More about motherboard help
  1. ASUS P8B75-V $95.98
    the rest are microATX which i am not a fan of
  2. what is the gpu clock rate of that MB?
  3. the gpu is on the cpu not the motherboard:
    http://ark.intel.com/products/53483/Intel-Pentium-Processor-G630-(3M-Cache-2_70-GHz)
    Processor Graphics Intel® HD Graphics
    Graphics Base Frequency 850 MHz
    Graphics Max Dynamic Frequency 1.1 GHz
  4. is asus P8H77-M LE is suited for me?
    is that below $100?
  5. where/what country are you buying from?
  6. india
  7. if you are using flipkart the only asus that falls in your budget is:
    ASUS P8H61-M LX Rs. 3074
    but that is not all that great. the H61 chipset has sata3 and usb 2.
    you would be better with a non asus:
    Gigabyte GA-B75M-D3H Rs. 4452
    with SATA 6 Gb/s USB 3.0 Ports and more DIMM slots for RAM.
    going over your budget ($100 = 5534Rs.)
    ASUS P8B75-M LE Rs. 6069
    but that does not have as many DIMM slots for RAM (2)
    what you asked about
    ASUS P8H77-MLE Rs. 7897 is not worth the price compared to a
    ASUS P8H67-M Rs. 7770
    Instant Cashback Rs. 466
    for that cpu. ( or any . .)
  8. what's the difference between B75 and H67 chipset?
  9. LGA 1155
    the biggest difference is the B75 will have one sata III port whereas the H67 will have two but it will not need an updated BOS to support an ivy bridge cpu.
  10. B75 or H67 which chipset is better for graphics?
  11. both are the same since it would be the intel graphics HD (2000, 2500, 3000 or 4000) on the cpu being used.
    1. Asus (company)
    3. onboard graphics
    please help
    its not in your budget but check this one
    http://www.flipkart.com/asus-p8z77-m-motherboard/p/itmd8b8vgvkry7g5?pid=MBDD8B8VKSWAZBGN&ref=84364c67-1fa4-45f1-87e0-16f523c9c58e
    and for $100 in our country today only available chipset is H61 from asus. I am large user of asus products. You have to know one truth about asus they are the hottest mother boards you can get literally. especially p8h61 m lx model's idle heat margins are 98 degrees. I have seen it in more than 125 boards of same model. so if you want a board with usb 3 below $100 try Asrock i don't like that brand but it's z68 boards are very good indeed.
    If you still insist for USB 3.0 (no difference for daily use for basic gaming and office purpose) then check these two
    http://www.flipkart.com/asrock-b75-m-motherboard/p/itmdcpws4sma3vkw?pid=MBDDCPWRUXHAVEYB&ref=b53de517-8f70-4e90-a626-4bdf3acced39
    http://www.flipkart.com/asrock-b75m-gl-motherboard/p/itmdcpwswcsehgdz?pid=MBDDCPWRGG6FGW5F&ref=b53de517-8f70-4e90-a626-4bdf3acced39
    For general usage USB 2.0 & USB 3.0 is identical, no big deal for rushing to buy a $200 board just for USB 3.0
    Here are some good boards. Try if they are available in your town
    http://www.flipkart.com/gigabyte-ga-z68xp-ud3-motherboard/p/itmd7bwb83rbycww?pid=MBDD7BWANXJZGKG9&ref=521d4aba-459c-4af1-8ed2-1c157b8a10b5
    http://www.flipkart.com/asus-p8z68-v-le-motherboard/p/itmd4g9hhstncsxk?pid=MBDD4G9G2VBY6HDK&ref=521d4aba-459c-4af1-8ed2-1c157b8a10b5
    http://www.flipkart.com/asus-p8z68-m-pro-motherboard/p/itmd4g9hebzaj7z5?pid=MBDD4G9GQ6ZPJDRR&ref=521d4aba-459c-4af1-8ed2-1c157b8a10b5
    http://www.flipkart.com/biostar-tz68k-motherboard/p/itmd4jvzj379bsnj?pid=MBDD4JVZAQTKPZHM&ref=521d4aba-459c-4af1-8ed2-1c157b8a10b5
    I know these are not in your budget, but these are the better boards with every paisa worth.
    :sol: :sol: :sol:
Motherboards Asus Pentium
