Hi Guys:
I (the newby) am going to build a new PC by keeping my existing graphic card (GTS 250) to saving some $$$. What do you think about this configuration? Any recommendation or comment?
Thanks a lot in advance.
Processor (CPU) Intel Core i7 2600K Quad Core Unlocked Hyperthreading Processor LGA1155 3.4GHZ Sandy Bridge 8MB
CPU Cooling Coolermaster V6GT CPU Heatsink Cooler LGA1155 LGA1156 LGA1366 AM3 2x 120MM PWM Fans 800-2200RPM
Motherboard ASUS P8Z68 Deluxe Z68 LGA1155 ATX 3PCI-E16 2PCI-E1 2PCI SLI CrossFireX USB3.0 SATA3 Motherboard
DDR3 Memory (RAM) Kingston HyperX KHX1600C9D3K2/8GX 8GB 2X4GB DDR3-1600 XMP Dual Channel Memory Kit
Computer Case Cooler Master Haf 932 Advanced Full Tower EATX Case 7X5.25 2X3.5 5X3.5INT USB3.0 eSATA 1394 Black
Power Supply Seasonic S12II 620W EPS12V 20/24PIN ATX Power Supply Active PFC 80+ Bronze 6+8PIN PCI-E W/ 120MM Fan
Hard Drives Western Digital Caviar Black 1TB SATA3 6GB/S 7200RPM 64MB Cache 3.5IN Dual Proc Hard Drive OEM
DVD Writer LG GH22NS70 Super Multi 22X SATA DVD Writer Black OEM
Solid State Drives - SSD Crucial RealSSD C300 64GB 2.5IN Solid State Disk Flash Drive SATA3 6Gbps
