Hey Everyone,
I just finished assembling a new build the other day and have been unable to get my system to have a display on screen. At the Display on the MoBo where is displays the POST codes i keep see the code 19 (Pre-Memory South Bridge iniation Started) and followed by POST code 55 which according to the MoBO manual means that the memory is not installed. So Far I have made sure all connections on the PC are secured and I have tried booting up with one stick of RAM in each slot. All fans and LEDs are powering up, HDD is powered up, Graphics card is powered up, all cards are secure, but i cannot get a display. Im lost as far as what might be wrong I have made sure that the RAM i have is compatibl with my MoBO. If anyone has any more suggestions please give your feedback.
CPU -Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I53570K
Video Card- EVGA 015-P3-1480-KR GeForce GTX 480 (Fermi) 1536MB 384-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
PSU - ABS Majesty series MJ1100-M Continuous 1100W@50°C ATX12V/EPS12V 80 PLUS GOLD Certified, Single 12V Rail, Modular Flat Cable Design, Active-PFC "Compatible with Core i7, i5" Power Supply
Case - NZXT Phantom PHAN-002OR Newegg Exclusive Black Finish w/Orange Trim Steel / Plastic Enthusiast ATX Full Tower Computer Case
Mobo - ECS Black Deluxe P67H2-A2 SLI (B3) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
HDD - Western Digital Caviar Black WD1002FAEX 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive - OEM
Heatsink - COOLER MASTER X6 Elite RR-X6NN-18PK-R1 Honeycomb Design 120mm Long Life Sleeve CPU Cooler NOT Compatible with High Heatsink RAM/Memory
RAM - CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CML8GX3M2A1600C9B
Optical -LITE-ON 24X DVD Writer 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM Black SATA Model iHAS424-98 LightScribe Support
