I just recently cleaned out my case for the first time in a couple years, and was it filthy. When putting it all back together, I began wondering if: A) I put the fans back blowing in the correct direction, and B) Whether the current fan setup is ideal for air flow.
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811119137
It has 3 120mm fans which are currently setup as follows:
1) low-front of case sucking in
2) high-back of case blowing out
3) mid-to-low side blowing out (over the graphicscard)
Places the fans can be moved to are:
1) top of case
2) high side of case (over CPU)
Any thoughts or reccomendations would be greatly appreciated. Thanks
1) top of case
