Planning on getting new mobo and ram, need help...
So, this year i have changed all parts of my PC except mobo and ram, but that will be accomplished soon. i got 4 gb ddr2 on 800 mhz, so my question is, if i get another 4 gigs of 800 mhz (to have total of 8gb ddr2 800mhz) , how much difference ( fps impact) would that be from 8 gb ddr3 some greater mhz's? Or should i just get new mobo with new RAM?
The reason i ask this is because if just getting 4 more gigz of RAM would do the trick, i wouldnt change mobo. Thanks in advance.
1 answer Last reply
More about planning mobo help
  1. *** when i said "will be accomplished" i meant "might be accomplished" edit button didnt work ..
Memory DDR2 RAM
