In 2008, with some advice from this forum, I ordered a lot of bits and my husband built them into a computer for me.
All has been so well in the meantime that I have pretty much forgotten what's under the hood though thankfully I kept notes of it all.
In the last couple of weeks I started to have a problem where the computer would freeze for ten seconds every minute. Gradually it got a bit less frequent but still disturbing. In the event viewer I couldn't see anything significant going on so I trawled around online a bit and looked at some similar problems in various forums. On their advice I installed Speedfan and a trial version of Active SMART.
The speedfan readout is confusing to me but with the program still on it's default settings it seemed the GPU was running too hot (53C) and the CPU was occasionally getting overwarm (highest 62C).
Taking it apart and giving it a good cleanout this morning has reduced the idling temperature to GPU 49C and CPU 46C and the stuttering effect has gone. In my relative ignorance I get the impression all is still not well and all it takes is a quick game and the GPU and CPU fly back to overhot (according to Speedfan).
From what I can read around possible actions would be
Remove the heatsink, clean and then reapply thermal paste?
Get a new fan (this one has always been noisy despite sold as quiet)?
Something else I don't know about?
I'd very much appreciate some guidance here as I feel I'm a bit out of my depth
Many thanks
Kathy
Specs:
Case: Antec P182 Advanced Super Midi Tower
Motherboard: Abit motherboard IP35-E Intel P35 LGA775 Core2 Quad / Core2 Duo / Core2 Extreme PCI-E x16 SATA 3G Gigabit LAN ATX
PSU: Antec NeoHE 550W Modular ATX2.0 + EPS12V PSU 80mm low speed/noise fan
CPU: Intel Core 2 Quad - Q6600 - 95W G0 stepping - OEM
CPU cooler: Cooler Master Hyper TX2 CPU Cooler
GPU: XpertVision GeForce 8600 GT 512MB DDR2, PCI-E
Many thanks
Kathy
Specs:
