HELP!!! fan connectors
so my motherboard only have 2 fan connectors ( cpu fan and case fan)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128504&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&AID=10440897&PID=3067296&SID=
and i have 4 fans including the cpu fan
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103022 and the cpu fan and
a free fan from the case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119227&Tpk=cooler%20master%20elite%20430
and i was wondering if you can connect like 3 case fans directly on this psu
http://www.newegg.com/Product/Product.aspx?Item=N82E16817256061
cause im sooo confused and i barely know anything on computers :cry:
1 answer Last reply
More about help connectors
  1. The cpu fan is probably a PWM fan that changes speed as the cpu gets hotter or cooler and should be run from the motherboard connector only .
    Its usual to run the rest of the fans directly from the four pin molex connectors on the PSU. Connect them all to one molex [or whatever looks tidy ]
New Build Cases Fan CPUs Systems Product
