Solved
Sports Betting Workstation Build - triple display - pls help
Hello All,
I've been sportsbetting online for a year now and this economy/job market hasn't really left me any options but to become a full time sports investor. I need to upgrade my current system so I can simultaneously monitor line movements, watch games, and place bets.
I don't have cable or satellite but rather stream all live sports events over the internet. For this NFL season I'll be using Sunday Ticket To Go and hopefully for NBA I'll be using League Pass. What I want is to be able to stream games to a large Television screen while having two LED monitors with an extended desktop for internet surfing and excel spreadsheets.
Other than that I need to be able to run basic office programs and internet browsing.
I have around $1000 to build a system not including monitors.
Thanks in advance,
YoungMoneyCashMoney
5 answers Last reply Best Answer
More about sports betting workstation build triple display help
  1. Approximate Purchase Date: Before NFL Season
    Budget Range: About $1000. Flexible.
    System Usage from Most to Least Important: 3 displays, streaming sports, excel, internet
    Parts Not Required: Monitors & TV
    Preferred Website(s) for Parts: amazon.com
    Country of Origin: US
    Parts Preferences: no idea
    Overclocking: Yes
    SLI or Crossfire: Maybe, if necessary
    Monitor Resolution: 1920x1080
    Additional Comments:
    Stuff I was looking at:
    Cooler Master HAF 932 Advanced Full Tower Case with SuperSpeed USB 3.0 - (RC-932-KKN5-GP)
    http://www.amazon.com/Cooler-Master-Advanced-Tower-SuperSpeed/dp/B001EPUQAE/ref=cm_cr_pr_product_top
    Corsair Enthusiast Series 750-Watt 80 Plus Bronze Certified Power Supply Compatible with Intel Core i3, i5, i7 and AMD platforms - CMPSU-750TXV2
    http://www.amazon.com/Corsair-Enthusiast-Certified-Compatible-platforms/dp/B004MYFODI/ref=sr_1_1?s=electronics&ie=UTF8&qid=1313723478&sr=1-1
    Corsair Vengeance Blu 16 GB PC3-12800 1600mHz DDR3 240-Pin SDRAM Dual Channel Memory Kit for Intel and AMD Platforms CMZ16GX3M4A1600C9B
    http://www.amazon.com/Corsair-Vengeance-PC3-12800-Platforms-CMZ16GX3M4A1600C9B/dp/B004RFBIUU/ref=pd_cp_e_pw_2
  2. Here is a build, trying to go low without compromising on quality,...
    i5 2400 + 8 GB DDR3
    I dont think you would need 16GB
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.694809
    CASE + PSU
    HAF 912 + CM Silent PRO 600W
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.710453
    HDD + Mobo
    Seagate 1TB + Biostar TZ68A+ LGA 1155 Intel Z68
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.711563
    Video card - Now this is the most important part,... To go 3 monitors, you would either have to go with a single costlier card which can handle multi-monitor setup or go with 2 cheap cards which run separately(no SLI/ Crossfire), which can handle 4 monitors,... I like the latter because say for ~$80 you can get 2 cards which can handle 4 monitors,...
    2x Radeon HD 5450 1GB
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814102882
    Maybe a SSD for boot
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820148441
  3. Thanks gkay for the ideas. Definitely makes sense on the two vid cards. How will the audio work on this? Will 7.1 surround output via the HDMI?
    Any advantage of an I5 over an AMD?
    Does that motherboard support 2 graphics cards?
  4. Best answer
    ^ I dont think it will do 7.1,...
    But had totally forgot about the HD 6xxx series cards that can push 4 monitors,... IMO even those will be good and will do 7.1 over the HDMI,...
    HD 6770 Flex allows for 3 monitor setup without the need of a DisplayPort or an Active adaptor, but if you want to get 4 monitor o/p, then you would need a monitor with DisplayPort or have to use Active adapter,...
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814102938
    i5 over AMD - Better overall performance,...
  5. Best answer selected by YoungMoneyCashMoney.
New Build Systems Product
