System dead after CPU swap?
So I just gotten done swapping out processors. Before the swap, everything was working fine. After the swap when I went to plug the psu back into the wall, all my fans starte to spin up like normal, only to cut out quickly. I got a wires little buzz from the psu and then nothing.
Now nothing spins up when I plug it in, but my motherboard as everything else lights up like normal. Did I manage to short something?
It's an Intel 790i Ultra an I had just swapped in a Qx6700
Everything was powered by the Dell 1Kw psu that came in their XPS systems
1 answer Last reply
More about system dead swap
  1. Did you try the old chip again? Have you cleared the CMOS? Have you verified that the new chip works in a different system?
Motherboards
