Hp desktop computer model 6520f cant log on when i check my battery
i remove the battery from my desktop because hp sent a letter to remove the battery.
i put the battery back in the computer and now i cant log on. please help
bourgeoisenergy@aol.com
pascal
1 answer Last reply
More about desktop computer model 6520f check battery
  1. And what was the reason to remove the battery?
    What means you can't log on? You can't log on where? In your Windows? Or your PC is password protected through your BIOS /boottime password protection/ and you completely can't access it? Or it just crashes?
    Just a suggestion:
    Your BIOS settings are reset as a result of removing the battery. Usually it should autoconfigure itself right but I suppose for some reason it doesn't happen in your case. If you can access the BIOS check if something is wrong with the config.
New Build Battery Desktops Hewlett Packard Computer Systems
