Not finding a lot of information on this configuration... I am getting ready to build out a system for upwards of 10k, but have a question about the z68 chipset and using the embedded video capabilities to run a separate monitor while having 3 monitors in an sli surround setup. Let me explain.
I am planning to buy a 2600k (overclocked to 5GHz) and the ASUS Maximus IV Extreme-Z. I am also planning to add 3 overclocked 3GB GTX 580's in 3-way SLI. I'll have 3 30inch 2560x1600 monitors running in portrait surround mode. I'd like to have a 4th monitor running to surf the web while I'm gaming across my surround setup. Can I do this and will it work? Will it slow anything down?
Before someone tells me to go the eyefinity route with a radeon solution, the radeons won't allow me to run multiple instances of the same game across my main monitor setup (multiboxing). This is a known issue and forces me to go the NVIDIA/SLI route.
I am also aware of the ability to add a 4th monitor with the surround setup just using my discreet cards. I know that this is an option, but would prefer not to do anything that would slow down my 3rd card. If I can have that 4th monitor running off it's own gpu, that'd be ideal.
I just want to know if I can add a 4th monitor running a web browser to the built in video provided by the z68/2600k combo while also keeping my sli surround setup running in top working order???
Advice on the best possible setup is much appreciated. I'm spending up to 10k here, so want to maximize every aspect of my investment.
