Is this power supply enough for the 6850?
  • Power Supplies
  • Components
  • Product
Last response: in Components
November 25, 2011 4:08:45 PM
Hello,
I was wondering...would the following power supply be enough for the following setup?
AMD Phenom II x4 965 Black Edition
8 GB Kingston HyperX DDR3 RAM
ASRock 970 Extreme3 Motherboard
Sapphire Radeon HD 6850 GPU
TWO 160gb Seagate 7200rpm Hard drives
a normal old dell DVD/CD RW thing
Thats about it. I'm really on a tight budget and that thing is within it, I heard good reviews but I want to be sure.
Thanks! :)
More about : power supply 6850
November 25, 2011 4:11:27 PM
40A on the +12V rail. Yes, it's way more than enough.
m
l
a b ) Power supply
November 25, 2011 4:17:59 PM
Looks fine to me. Antec is a top tier PSU maker.
m
l
a c 1218 ) Power supply
November 25, 2011 4:19:47 PM
For a system running with a single Radeon HD 6850 graphics card a minimum of a 500 Watt or greater power supply with a combined +12 Volt continuous current rating of 24 Amps or greater and with at least one 6-pin PCI Express supplementary power connector is recommended.
The Antec NEO ECO 520C, with its combined +12 Volt continuous current rating of 40 Amps and with one 6-pin and one 6+2 pin PCI Express supplementary power connectors is more than capable.
m
l
November 25, 2011 4:36:11 PM
Awesome, thanks a bunch! :)
So happy I don't have to spend extra on a different one. I might though, if I decide to get a better card or go crossfire.
m
l
November 25, 2011 4:36:51 PM
Awesome, :)  Good thing I don't have to spend more on a psu. Thanks a bunch guys.
m
l
