Solved
Feed Back on parts and suggestions please. PCIE3,0
Last response: in Systems
Approximate Purchase Date: November 2011
Budget Range: 1700-1800
System Usage from Most to Least Important: Gaming, App dev. adobe products, general use, server running, programing
Parts Not Required:keyboard, mouse, monitor, speakers, OS
Preferred Website(s) for Parts: Australian websites, like cpl.net.au and msy.com.au
Country of Origin: Australia
Parts Preferences: by brand or type: Intel
Overclocking: Yes
SLI or Crossfire: Maybe
Monitor Resolution: 1920x1200
Additional Comments: Here is compents i have picked, this is to verify the awesomeness of the build, i plan on doing an ivybridge upgrade and a new gpu(AMD 7XXX) by end of 2012.
MSI Z68A-GD80 (G3) pcie 3.0
i5 2500k
Gskill 8G 1600C9 Sniper
MSI 1G GTX560OC Twin Frozr II
Stock cpu cooler
C/Master M/Silcent ProM1000W Gold
C/Master HAF 912A USB3
Seagate 1TB SATA3 7200
OCZ 240 Agitity 3
LG Blu-Ray Combo
My Total Price ATM is $1689, but in Australia, feed back would be appericiated :D
750w is what you want to power dual 560's.
PCI-E 3.0 boards down below.
http://www.pccasegear.com/index.php?main_page=product_i... $149.00
ASRock Z68 Extreme3 Gen3 Motherboard
http://www.pccasegear.com/index.php?main_page=product_i... $209.00
ASRock Z68 Extreme4 Gen3 Motherboard
http://www.pccasegear.com/index.php?main_page=product_i... $319.00
ASRock Z68 Extreme7 Gen3 Motherboard
http://www.asrock.com/mb/index.asp?s=1155 <---- the boards that say Gen3 have the PCI-E 3.0 slots
If you have a budget the size of yours, then spend a few dollars on a h/s
http://www.pccasegear.com/index.php?main_page=product_i... $33.00
CoolerMaster Hyper 212+ CPU Cooler
http://www.pccasegear.com/index.php?main_page=product_i... $139.00
Antec High Current Gamer 750W Power Supply HCG-750
Related ressources
siege_templar said:
might grab this psu instead
and the msi board is gen3 pcie. i havent found them on any websites yet though.
AND on the cooler, thanks, might get that, or might go a bit higher, whats the next best cooler for like a 4.6ghz oc?
Thermaltake Frio for a few dollars more, or if you can find it...the Scythe Mugen 3. Otherwise your going to spend a small fortune.
All those Gen3 boards I linked up above all have the PCI-E 3.0 slots.
Best solution
siege_templar said:
Thanks, but the AsRock boards only have 1 pcie gen 3 slot, and the msi board has to as well as 1 more pcie gen 2, i may got to a 3 way card setup down the track.
I'm not sure how you got that. For example if you click the link to that extreme3 gen3 board to pccasegear and read the specs it says right on there: 2 x PCI-Express 3.0 next to "Slots".
FINAL COMPONENTS:
i5 2500k
MSI 1G GTX560 TIHAWK
Noctua NH-U9B-SE2
Corsair HX-850W
OCZ 240 Agitity 3
LG Blu-Ray Combo
TOTAL COST: $1740.
Thanks why me heaps :D
Ask the community
