Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > Possible Backspace or Motherboard Problems with Dell Inspi..
Forum Laptops & Notebooks : General Laptops & Notebooks - Possible Backspace or Motherboard Problems with Dell Inspi..
Archived from groups: comp.sys.laptops (More info?)
This Inspiron has a Phoenix BIOS. On boot, the computer beeps several
times, then goes into a DOS screen, which asks for normal boot or
alternatives. When normal boot is chosen, the boot process is fairly
normal. Odd things then occur. Sometimes the left half of the desktop
flashes- can be stopped by hitting a key. More recently, a section of
the keyboard became inoperative. An accessory keyboard cured the
problem.
MOST recently, on boot, the computer beeped continuously as if
it was going to continue indefinitely. Finally it stopped and it
booted but very slowly.
I have most of my hard drive backed up in anticipation of a
complete system failure. I also have a new laptop ready to go if
need be.
My question is this: Is the motherboard about to fail and are all
these problems likely related? I checked the BIOS beep codes
for Phoenix, and nothing much is mentioned about continuous
un-paused beeps.
Help much appreciated!
Frank
P.S. This doesn't seem like a virus problem to me. I run Norton
periodically but haven't in awhile. Will any known viruses cause
this kind of behavior? It sure looks like BIOS or hardware to me.
Sponsored Links
Of course I meant BIOS or motherboard problems....sorry
On Mon, 22 Aug 2005 16:19:35 GMT, frank1492
>problem.
>need be.
>un-paused beeps.
> Frank
Reply to Anonymous
- 0 +
> problem.
> need be.
> un-paused beeps.
> Frank
With half of the screen flashing on and off sometimes, and half of the
keyboard not working other times, and combinations of the above, the first
thing I might wonder about is if the notebook had been dropped or severely
jostled recently and if maybe some cables (screen and keyboard, perhaps)
had been shaken loose. If you're not afraid to open it up, I'd check to
make sure that the connectors for the screen and keyboard to the mainboard
are firmly in place. At that it wouldn't hurt to check that everything,
from RAM to HDD are all seated firmly.
If this doesn't help, then yes, you may very well be looking at a bad
motherboard, given that two components unrelated to each other but both
connected to the motherboard have stopped working properly, the common
element is likely to be the problem.
-dirk
Reply to Dirk
Thanks. No the computer was not jostled or dropped to my
knowledge.
I am using an accessory keyboard now and everything seems
normal, but earlier the accessory keyboard didn't work either.
It is interesting that some major problem always seems to
occur between 2.5-3 years into the life of my laptops. Two
previous Thinkpads had screen problems. That's why I switched
to Dell. This computer will be three years old in February!
Do you know if any studies have been done on people's
experiences regardng laptop life? One factor that may bear heavily on
my problems is that the laptop is my sole computer and therefore gets
heavy use.
In light of my exepriences it is probably best to go to a new
laptop as other things may start to occur.
Thanks again.
Frank
P.S. Could a bad keyboard alone possibly cause the symptoms
I have?
>> problem.
>> need be.
>> un-paused beeps.
>> Frank
>-dirk
Reply to Anonymous
- 0 +
On Mon, 22 Aug 2005 21:44:18 GMT, frank1492 <frank1492@worldnet.att.net> wrote:
>knowledge.
Wouldn't be the CMOS battery? While back I got hands on an old
Thinkpad (365X), tiny lithium button was flat. You can get
replacement keyboards, also, connections can go iffy over time,
a lot of 'refurbishment is simply reseating all the connectors.
Grant.
Reply to Grant
There are 629 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 tehue won the Freshman badge
  • 12:11 mi1ez won the Watchman badge
  • 01:00 sighQ2 won the Freshman badge
  • 09:06 ulysses35 won the CPUs badge
  • 01:00 fleeb won the Freshman badge
  • 01:00 jaymoney61 won the Freshman badge
  • 07:06 amdfangirl won the Watchman badge
  • 01:00 benw won the Freshman badge
  • 01:00 anmjoven won the Freshman badge
  • 01:00 dpnaugle won the Freshman badge
