Closed
Will this TV tuner card fit in pci x16 slot?
  • TV
  • Tuner
  • Connection
  • PCI
  • Components
Last response: in Components
November 26, 2011 2:02:51 PM
no it wont fit.......pci and pci express are two different interfaces..not the same
Score
November 26, 2011 2:37:02 PM
So this card is for regular PCI?
Score
Best solution
November 26, 2011 2:41:49 PM
Yes it is for regular PCI, the keying slot at the back of the card(away from the mounting bracket) gives that away. Chances are your board has at least 1 PCI slot, so open the system up and see.
November 27, 2011 12:47:10 AM
Your right hunter! Stupid me thought that slot was pci x16 when indeed its PCI. Thank you both so much you helped a lot.
Score
November 27, 2011 12:47:38 AM
Best answer selected by VinnyA+.
Score
