How to get the power button LED to work?
My case (Coolermaster HAF 912) apparently has 2 LEDS in the front of the computer between the power and reset button.
I have a Gigabyte Z68XP-UD3 and when I build the computer (first build) a while ago I noticed something that said POWER LED +/- or something like that on the motherboard, you connected the USB 2-pin and some other stuff to it.
My question is, how can I get the LED to show up so I can know when the computer is on or on sleep mode. This isn't important, I don't exactly need it but it would be useful sometimes.
Thanks.
3 answers Last reply
More about power button work
  1. Checked the HAF912 manual? It's probably stated there. (Or check your mobo's manual).
    Some of these kind of things which you get with the HAF912 -
    http://www.gophoto.it/view.php?i=http://www.silverstonetek.com/images/qa/WB090112/wb112-4.jpg
    Go into something like this -
    http://www.gophoto.it/view.php?i=http://www.mysuperpc.com/build/motherboard_system_panel_connectors.jpg
  2. Thanks. But that says H.D.D?
  3. No, it'll be saying Power L.E.D or something similar.
Motherboards Computer Power LED Monitor
