New Build Power Supply Question
I have just set up my new build and am looking to upgrade my graphics card.
Setup - i5 2500k w/212+, ASRock P67 Extreme4, 4GB G.Skill, Radeon HD5670, Corsair 500CX, 500GB HD. I think thats about all that needs to be listed.
Anyways I am looking at getting a GTX 460 or GTX 560 Ti and im curious if either of those cards can run off my PSU which is a Corsair 500CX. I'm going to be making this purchase on Monday.
GTX 460 - MSI GTX 460 Hawk
http://www.directcanada.com/products/?sku=12980BD7883&vpn=N460GTX%20HAWK&manufacture=MSI
GTX 560 Ti - MSI GTX 560 Ti
http://www.newegg.ca/Product/Product.aspx?Item=N82E16814127565
Also im open to suggestions on the GTX 560 Ti but the price has to be under 240$ from either newegg canada or directcanada
8 answers Last reply
More about build power supply question
  1. well if u want a gtx 560 ti here is 1 at ur price range http://www.newegg.com/Product/Product.aspx?Item=N82E16814130651
    Edit:ull need atleast 500w so i would highly recommend u get another PSU
    here is a good PSU for u http://www.newegg.com/Product/Product.aspx?Item=N82E16817151095&Tpk=m12%20620w its 620w alot more yea maybe if u find a good 600w PSU would be great
  2. I already have a 500W PSU from Corsair, it's the 500CX. My question was is that power supply enough to run that system with a GTX 560 Ti or GTX 460
  3. Try this
    http://extreme.outervision.com/PSUEngine
    144 watts for the 560Ti versus about 26 for the HD5670
    Using the calculator with Hi end desktop, 2500k OC'd to 4.6 Ghz, 2 sticks of RAM,1 hi rpm HD, 3 USB devices, and 15% capacitor aging, the calculator comes up with a recommendation of 506 watts.
  4. The 500 cx will work just fine. You have 2 x 6+2 pin PCI-e power connectors and have 34A on the 12v rail, so there shouldn't be any issues whatesoever. The PSU is 80+ rated and has a 3 yr. warranty too, so buy your GPU and enjoy :)
  5. the minimum power required for the 560 ti is 500w so i think u wont be able 2 overclock and the 560 ti is the overclocked version of the 560 so u can just get a 560 non ti
    Are you kidding?? 500cx is plenty for his build, even considering OC'ing too!
    CPU - 95 w
    GPU - 100-130 w
    rest of parts - 75w or so
    Total ~270-325w or so, I'm just ball parking it. That leaves about 150-200w for OC'ing or whatever and this is if every part is fully stressed 100% of the time.
    CPU - 95 w
    GPU - 100-130 w
    this is the 560 ti specifications and requirments page it says u need atleast 500w for the GPU i dont know much bout PSUs but this PSU dusn seem 2 be enough for 560 TI as its a 500w
    http://www.geforce.com/Hardware/GPUs/geforce-gtx-560ti/specifications
  8. I'm running a 6850 on a Antec 380w PSU, so a 560 ti on a Corsair 500 cx is going to be a piece of cake, even with OC'ing (if that is used). Most single GPU gaming systems run around 250-350w before any OC'ing.
New Build Gtx Power Supplies New Build Systems Product
