Tom's Hardware > Forum > Digital Camera > Digital Camera General > Does anyone know the shutter lag for the Pentax *ist DS?
Forum Digital Camera : Digital Camera General - Does anyone know the shutter lag for the Pentax *ist DS?
Archived from groups: rec.photo.digital (More info?)
I've searched the web for the shutter lag time in SECONDS for the *ist
DS, with autofocus on, and can't find this info.
Some places say there is no noticeable lag, some that the *ist is
"slow"... but nobody has posted an actual delay time in seconds or
milliseconds.
The D70 and Digital Rebel are also often described as having virtually
no shutter lag, but in fact when measured it is around 250-490
milliseconds.
So if you have this info, pls post.
A.
Sponsored Links
I can't find it either but is is similar to the D70 and 300D and has
virtually no shutter lag, the Ds is not "slow" unless perhaps comparing it
to a D1.
"Archie" <Archie@Hatespam.com> wrote in message
news:2gae41litrr5ljrummhtf6cvdguqr81ru4@4ax.com...
> milliseconds.
> milliseconds.
> A.
Reply to Anonymous
(snip)
some figures are given here:
http://www.steves-digicams.com/200 [...] s_pg7.html
(rounded to the nearest 0.1 sec)
It is said to be similar to the D70, and faster than the 300D.
C
Reply to Anonymous
"CyaD" <CyaD@(news)btinternet.com> wrote in message
news:d28m0c$2f7$1@titan.btinternet.com...
> (snip)
> C
Thanks.
Reply to Anonymous
"Pete D" <no@email.com> wrote in message
news:BcR1e.15589$C7.10595@news-server.bigpond.net.au...
>> (snip)
>> C
> Thanks.
The shooting performance of the *ist DS is quite robust for an amateur
dSLR; it equaled and in some cases exceeded the responsiveness of the *ist
D. From power-on till the first image was captured measured only one second.
Shutter lag, the delay between depressing the shutter and capturing the
image, was 1/10 second when pre-focused, and 3/10 second including autofocus
time for a high-contrast subject. Shot-to-shot delay averaged about 1/2
second without flash; the internal flash recycle time extended shot-shot
delay to between 1.3 and 4.2 seconds, depending on subject distance.
Continuous Shooting mode captured nine shots in three seconds, with
subsequent shots at a rate of one every 6/10 second as the camera is
processing the contents of the buffer. It required ~7 seconds to write a
buffer full of JPEG images to SD card before being ready to capture the next
burst. This puts the *ist DS ahead of the *ist D and Canon Digital Rebel
both in its burst capture rate and the size/speed of its buffer, trailing
the Nikon D70 by only a slight margin. The above times were observed using a
fast Delkin 1GB SD memory card, 18-35mm FA lens, flash off, daylight
lighting, 3008x2008 JPEG/Fine.
Reply to Anonymous
On Mon, 28 Mar 2005 10:24:12 +0000 (UTC), "CyaD"
<CyaD@(news)btinternet.com> wrote:
>(snip)
>http://www.steves-digicams.com/2004_reviews/istds_pg7.html
>C
Thanks! Useful.
Reply to Anonymous
>milliseconds.
>milliseconds.
>A.
I got 0.1 seconds when prefocused, 0.2 seconds on autofocus under
bright contrasty lighting, and 0.6 seconds under low contrast
lighting. (There is no focus assist lamp.) Shot-to-shot times were
about a second with flash, and 3 seconds with flash, up to about 5
frames.
Everything I know, and then some:
http://www.auctionmyths.com
Reply to Anonymous
There are 856 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
