CM 690 ii front panel USB 3 cable doesn't plug into my Motherboard
- SolvedCan i plug a USB front panel cable to a usb 1364 socket in the motherboard? Forum
- Front Panel USB 3.0 cable for ASUS motherboards Forum
- Where do I plug in my USB 3.0 front panel?! Forum
- The front panel ribbon cable on my XPS 710 won't plug into my 720 motherboard, w Forum
- SolvedCase has front panel USB 3.0 ports, but the Motherboard does not have onboard USB 3.0 headers. Forum
- SolvedPhantom 410. What HD Audio cable is for? And some other cables.. And a problem with usb 3.0 front panel.. Forum
- SolvedUSB 3.0 header on motherboard but USB 2.0 front panel port on case Forum
- SolvedMotherboard lacks connector for Front panel 3.0 USB port Forum
- CM Elite 431 Plus USB 3.0 Front Panel Keeps on dropping connection Forum
- SolvedI can't connect my case front panel USB 3.0 with my motherboard Forum
- Motherboard has 10-1 USB Socket, Case front USB cable has 5pin plug all connecte Forum
- CM 690 II Advanced (USB 3.0 version) or Corsair Carbide 400r Forum
- CM 690 II Advanced (USB 3.0) grounding issues? Forum
- Need help connecting computer usb3 front panel to Z68 motherboard Forum
- Motherboard has USB 3.0 while case front panel only has USB 2.0 Forum
- More resources
Read discussions in other Motherboards categories
