Hello everyone
So i've been having some audio issues the thing is the computer thinks that no headphones or speakers are plugged in even though they are plugged in the correct ports that used to work before and when i view device manager everything looks normal and no yellow triangle or any issues there and i have the latest drivers.
i also tried to uninstall and reinstall the drivers but no luck then i reinstalled windows still no luck
i'm on a windows 7 64 bit
Motherboard is : MSI 790GX-G65 Winki Edition
note: this a windows 7 but using the classic mode for more performance
Device manager: http://img33.imageshack.us/img33/740/devicemanagert.png
Dxdiag : http://img840.imageshack.us/img840/836/dxdiagvy.png
Playback devices: http://img145.imageshack.us/img145/1981/playbackdevices.png
so did the onboard card die? or there is something else
also 'HD Audio controller' is enabled from the system bios
if there is any more info needed i will happily provide
thank you so much for any help
