Sign-in / Sign-up
Need advice on which build to go with! Can anyone help?
  • New Build
  • Systems
  • Product
Last response: in Systems
August 28, 2011 10:33:27 PM
Hello everyone,
For the past month I have been constantly tweaking these two builds, and I think they are finally good. I would like to run Mac OS X Snow Leopard, then use Boot Camp for Windows 7 to play games, or dual boot.
I would like to be easily able to upgrade in the future, switching out video cards, adding RAM, etc.
So, the question is, my Intel build, or my AMD build?
Approximate Purchase Date: Within a month
Budget Range: ~$750
System Usage from Most to Least Important: Gaming, Everyday Use (Internet, iTunes), School use
Parts Not Required: Keyboard, Mouse, OS
Preferred Website(s) for Parts: Preferably Newegg.com, but I'm also open to Amazon.com and Tigerdirect.com
Country of Origin: USA
Parts Preferences: None really
Overclocking: Probably not for now, this is my first build after all.
SLI or Crossfire: Not for now.
Monitor Resolution: The monitor I'm going to get says 1600 x 900
Additional Comments: What do you guys think? Here are the two builds:
INTEL BASED BUILD:
Processor: Core i5 2400 Sandy Bridge 3.1GHz Quad-Core - $189.99
Motherboard: ASRock H61M-VS LGA 1155 Intel H61 Micro ATX Intel Motherboard - $59.99
Graphics Card: Sapphire Radeon 6870 HD 1GB GDDR5 (Comes with free Deus Ex: Human Revolution game coupon) - $174.99
RAM: G.SKILL Ripjaws Series 4GB DDR3 1333 SDRAM - $24.99
Hard Drive: Seagate Barracuda 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive - $74.48
http://www.newegg.com/Product/ComboDealDetails.aspx?Ite...
Power Supply: Rosewill 600W ATX12V v2.01 SLI Ready - $94.98
Case: Rosewill Challenger ATX Gaming Mid-Tower 3 fans, 1 top, 1 front, 1 rear, option to add two on the side
(See Power Supply)
Disc Drive: Asus DRW-24B1ST/BLK/B/AS Black Sata 24X DVD Burner
(See Hard Drive)
Wireless Adapter: TP-LINK 802.11b/g/n up to 300Mbps - $24.99
Monitor: Acer Black 20" 5ms LED Backlight, LCD Monitor (1600 x 900) - $109.99
Speakers:Logitech S120 2.3 Watts (RMS) 2.0 Speaker System - OEM - $16.99
Total Cost: $772
AMD BASED BUILD:
Processor: AMD Phenom II X4 965 Black Edition (Comes with free Battleforge Game Coupon) 3.4 GHz Quad-Core - $129.99
Motherboard: BIOSTAR A870 AM3 AMD 870 SATA 6Gb/s ATX AMD Motherboard - $59.99
RAM: G.SKILL Sniper 8GB (2 x 4GB) DDR3 1333 SDRAM - $48.99
Case: Rosewill Challenger Black Gaming Case, ATX, 3 fans, 1 top, 1 front, 1 rear, option to add 2 in the side
(See Power Supply)
(See Hard Drive)
Speakers: Logitech S120 2.3 Watts (RMS) 2.0 Speaker System - OEM - $16.99
Total Cost: $736
So, what do you guys think I should go with? Intel, or AMD? Again, keep in mind I would like to dual boot Snow Leopard and Windows 7, or use Boot Camp, but I want a good gaming PC that I can upgrade when I need to, and preferably the build should last for a few years running games on decent to high settings.
Thank you to anyone who helps me decide.
More about : advice build
August 29, 2011 12:05:07 AM
Neither .
The rosewill case is Ok , but the power supply is not known as a quality unit
The H61 mb is a very limited little puppy so that really shoots down the intel , for me . There are P67 motherboards available for $80
MSI P67S-C43 (B3) LGA 1155 Intel P67
The AMD processor is not as strong , but is easily strong enough . The problem here too is the motherboard which is about to be obsolete when AMD introduce their new Bulldozer processors . No point in the 965 when the 955 is the exact same part and costs less . Overclocking it to 965 speed and beyond is simple with a modern motherboard .
ASUS M5A97 AM3+
Phenom 955
2 x2 gig of 1600 MHz , 1.5 volt RAM
CORSAIR Enthusiast Series TX650 V2 650W ATX12V $70
Quality unit with a good record and $30 cheaper
Making the changes to the AMD build I have suggested my make a bigger 1080p monitor fit in your budget
Of the two cases I prefer the Antec . Its well made , has great cooling . The 300 illusion is a good deal for the added fans .
m
l
