Hello
I recently bought an Asus P8Z77-V LX motherboard. Put it in a Fractal Design Define R4 case.
Today I had some issues powering on my system. I pushed the power on button several times but nothing happened. Then I tried pushing the button really really gently and slow. At some specific point of pressing very smoothly, the system turned on. Then I had to do the exact same thing to power off...
After a while I tried turning my system on again without any issues. I just pushed the button and turned on...
It appears to have that problem at random times... or I cant really tell what causes it.
I first thought it was a case problem. But that randomness makes me think it may be the motherboard too.
Any ideas?
Thanks!
Any ideas?
Thanks!
