Closed
Please help me choose my power supply
  • Power Supplies
  • Components
  • Product
Last response: in Components
November 28, 2011 8:24:13 AM
hello guys,i want to buy a gpu and a power supply
i have a pc that i bought in 2009,here is its configuration
CPU: intel core 2 duo e7400 2.8 ghz fsb1066 mhz
MOBO: gigabyte g45-ud2h g45+ichr10
RAM:2 gb transcend 800 mhz (1+1) dual channel
HDD: 500 gb 7200rpm western digital
PSU:Chinese 400 watt low quality
GPU:intel hd4500x with dx10 sm4 support
DVD:asus 24x dvd writer
Case: delux high quality thermal case with 2 rear 80mm fans
Montior: samsung syncmaster 19" 5ms Widescreen LCD Monitor with vga adapter resulation1366x768
so you guys can see that my build lack in 3 items generally(of course there are other things but i donot have money)
those are gpu, power supply,ram
in my region only thermal take power supply,sapphire-gygabyte-asus gpu ,transcend ram is found so i am stuck with these
but i donot know which model is suitable for me please refer me some models
the things i want to do with my pc:gaming ,3d rendering,programming,ai(artificial intelligence)computing, office and graphics work.
N.B: i am thinking of upgrading its cpu and motherboard in 18 months
here are some models that i am thinking to be suitable
1. power supply
http://www.newegg.com/Product/Productcompare.aspx?Submit=ENE&N=100007657%2050001379%20600014021&IsNodeId=1&bop=And&CompareItemList=58%7C17-153-114%5E17-153-114-TS%2C17-153-125%5E17-153-125-TS%2C17-153-140%5E17-153-140-TS%2C17-153-151%5E17-153-151-TS
http://www.newegg.com/Product/Productcompare.aspx?Submit=ENE&N=100007657%2050001379%20600014019&IsNodeId=1&bop=And&CompareItemList=58%7C17-153-023%5E17-153-023-TS%2C17-153-138%5E17-153-138-TS%2C17-153-150%5E17-153-150-TS
http://www.newegg.com/Product/Productcompare.aspx?Submit=ENE&N=100007657%2050001379%20600014022&IsNodeId=1&bop=And&CompareItemList=58%7C17-153-131%5E17-153-131-TS%2C17-153-129%5E17-153-129-TS%2C17-153-152%5E17-153-152-TS%2C17-153-126%5E17-153-126-TS%2C17-153-116%5E17-153-116-TS
2.graphics card
http://www.newegg.com/Product/Productcompare.aspx?Submit=ENE&N=100007709%2050001561%204017&IsNodeId=1&bop=And&CompareItemList=48%7C14-102-948%5E14-102-948-TS%2C14-102-924%5E14-102-924-TS
http://www.newegg.com/Product/Productcompare.aspx?Submit=ENE&N=100007709%2050001315%204017&IsNodeId=1&bop=And&CompareItemList=48%7C14-121-477%5E14-121-477-01%23%2C14-121-478%5E14-121-478-01%23%2C14-121-446%5E14-121-446-TS%2C14-121-391%5E14-121-391-TS%2C14-121-418%5E14-121-418-TS
http://www.newegg.com/Product/Productcompare.aspx?Submit=ENE&N=100007709%2050001314%204017&IsNodeId=1&bop=And&CompareItemList=48%7C14-125-383%5E14-125-383-TS%2C14-125-367%5E14-125-367-TS%2C14-125-333%5E14-125-333-TS%2C14-125-357%5E14-125-357-TS
http://www.newegg.com/Product/Productcompare.aspx?Submit=ENE&N=100007709%2050001315%204017&IsNodeId=1&bop=And&CompareItemList=48%7C14-121-466%5E14-121-466-TS%2C14-121-420%5E14-121-420-TS%2C14-121-418%5E14-121-418-TS%2C14-121-391%5E14-121-391-TS%2C14-121-446%5E14-121-446-TS
http://www.newegg.com/Product/Productcompare.aspx?Submit=ENE&N=100007709%204017%20600083901%20600083829&IsNodeId=1&bop=And&CompareItemList=48%7C14-102-948%5E14-102-948-TS%2C14-125-357%5E14-125-357-TS%2C14-102-924%5E14-102-924-TS%2C14-150-561%5E14-150-561-TS%2C14-150-521%5E14-150-521-TS
http://www.newegg.com/Product/Productcompare.aspx?Submit=ENE&N=100007709%2050001669%204017%20600083901%20600083829&IsNodeId=1&bop=And&CompareItemList=48%7C14-150-561%5E14-150-561-TS%2C14-150-521%5E14-150-521-TS
http://www.newegg.com/Product/Productcompare.aspx?Submit=ENE&N=100007709%20600094002%204018%20600107147&IsNodeId=1&bop=And&CompareItemList=48%7C14-121-424%5E14-121-424-TS%2C14-125-363%5E14-125-363-TS%2C14-121-425%5E14-121-425-TS%2C14-125-401%5E14-125-401-TS
so guys i have tried my best to make this post as detail as possible so please give your replies as detail too.
thank you very much
nibir2011
More about : choose power supply
a c 87 ) Power supply
November 28, 2011 4:12:10 PM
The Toughpower XT 575, 675 and Toughpower Grand 650W are the best of the ones in those lists. The TR2-700P recently received a positive review at Hardwaresecrets so you would probably be okay getting that one as well.
If your programs use CUDA then it would make sense to get the highest end Nvidia card (GTX 460 or 560) you can. Otherwise the 6870 is what I would get.
Score
a b ) Power supply
November 28, 2011 4:25:54 PM
I agree, it sounds like you are doing some big stuff which should get a boost from CUDA. Go buy the nVidia card with the most CUDA cores you can afford, and a PSU to match it.
If your software does not support CUDA then I would highly suggest refreshing your core system instead as it is very outdated for such use.
Score
November 29, 2011 5:07:21 AM
caedenv
you mean i need to change my processor to use cuda
Score
November 30, 2011 1:04:20 PM
man cannot buy these i cannot buy from web i can buy only from stores so i am stuck with these
but i have short listed two gpus 1.gtx 560ti 2.hd6870
dont know which to choose
please give me some advice about the power supply
Score
a c 1218 ) Power supply
November 30, 2011 4:28:01 PM
From all of the graphics cards you've listed the GeForce GTX 560 Ti draws the most power.
For a system running with a single GeForce GTX 560 Ti graphics card NVIDIA specifies a minimum of a 500 Watt or greater power supply having a combined +12 Volt continuous current rating of 30 Amps or greater and having at least two 6-pin PCI-Express supplementary power connectors.
Of the power supply units you've listed, only four are really worthy of consideration as listed by @Silvune and @davcon and will handle any of the graphics cards you've listed:
Thermaltake TR2 Series 700W (TR-700P) (TR2-700AH2NFB) with its +12 Volt continuous current rating of 57 Amps and with two 6-pin & two 6+2-pin PCI-Express supplementary power connectors
Thermaltake Toughpower XT 575W (TPX-575M) with its +12 Volt continuous current rating of 48 Amps and with one 6-pin & one 6+2-pin PCI-Express supplementary power connectors
Thermaltake Toughpower XT 675W (TPX-675M) with its +12 Volt continuous current rating of 56 Amps and with two 6-pin & two 6+2-pin PCI-Express supplementary power connectors
Thermaltake Toughpower Grand 650W (TPG-650M) with its +12 Volt continuous current rating of 52 Amps and with two 6-pin & two 6+2-pin PCI-Express supplementary power connectors
Score
November 30, 2011 4:54:42 PM
i really need to know that if i buy a thermaltake toughpower xt 675 watt will it be enough for sli in future.
another important thing how big case and how many fans are needed to keep my gpus under 60 celcias at load.
because they can be run for about 10-12 hours per day .
any suggestion
Score
November 30, 2011 5:03:10 PM
For a system running with two GeForce GTX 560 Ti graphics cards in 2-way SLI mode a power supply with a +12 Volt continuous current rating of 44 Amps or greater and with at least four 6-pin PCI-E Supplementary Power Connectors is recommended.
The Thermaltake Toughpower XT 675W (TPX-675M) meets all of the requirements and even has ample reserve capacity.
What is the room temperature where this system is going to be running?
Score
December 1, 2011 4:34:18 PM
room temperature can be from 25 degrees at winter and 40 degrees at summer
N.B. i donot have a ac in my room
Score
December 1, 2011 5:25:16 PM
more replies please
Score
December 1, 2011 5:27:50 PM
All of the cards you've listed are going to be dumping at least half or more of their heat load back into the case because of their GPU cooler design.
Keeping your GPUs under 60°C at full load on air cooling using the stock GPU coolers, in the 25°C to 40°C room temperature range that you've specified, isn't ever going to happen. You can't violate the laws of thermodynamics.
Even in a test lab kept at 21°C with the graphics card in an open air environmrent where none of the heat load is recirculated:
Radeon HD 6870
Idle GPU Temperature: 40°C
Load GPU Temperature - Crysis: 72°C
Load GPU Temperature - FurMark: 81°C
GeForce GTX 560 Ti
Idle GPU Temperature: 28°C
Load GPU Temperature - Crysis: 75°C
Load GPU Temperature - FurMark: 79°C
Score
December 1, 2011 5:47:36 PM
you mean even how many fans i use it is not going to stay under 60°C at full load
but still the question remains how big case and how many fans are needed to keep
my gpus under desirable Temperature so that my cpu,mobo and gpu do not get fried
Score
December 1, 2011 6:13:02 PM
NVIDIA states a Maximum GPU Temperature 99°C for the GeForce GTX 560 Ti. The graphics card will most likely start producing graphics artifacts before it even reaches that temperature.
Your case description "Case: delux high quality thermal case with 2 rear 80mm fans" doesn't tell me much.
80mm fans are considered rather small and they are noisier when they have to deliver a high air flow.
Get a large case with at least two 120mm intake fans and two or three 120mm exhaust fans with good air flow.
Score
December 2, 2011 1:17:00 PM
my current case is this one
delux
http://www.hardwarest.com/product/Delux-DLC-MG432-450W-Silver-black-120314.html
if my case above is not suitable
i have also short listed some cases that i can access and within my budget
thermaltake Element G
1.http://www.ucc-bd.com/thermaltake-chassis-element-g.html
Thermaltake Element V Black Edition
2.http://www.ucc-bd.com/element-v-black-edition-black-win-secc.html
Thermaltake Armor A60 AMD Edition
3.http://www.ucc-bd.com/thermaltake-armor-a60-amd-edition-black-win-secc.html
note that it has a Graphic card length limitation: 305mm can that be a problem.amd sign is not a problem for me
Thermaltake V9 BlacX Edition
4.http://www.ucc-bd.com/thermaltake-v9-blacx-edition-black-win-secc.html
note that it has a Graphic card length limitation: 244mm can that be a problem
please give me some suggestion
thanks in advance
Score
a c 275 ) Power supply
December 2, 2011 2:23:12 PM
I wouldn't pay too much for a Thermaltake case.
Thermaltake is low on my list for a case maker.
Save your money for other stuff.
I would go with the Dokker or V6.
http://www.ucc-bd.com/products-1/search-brand/thermalta...
I agree you need a better case then what you have atm.
Score
