Can a APEX AL-D500EXP 500W ATX12V Power Supply go into a hp desktop?
  • Power Supplies
  • Desktops
  • Hewlett Packard
  • HP Pavilion
  • Components
  • Product
Last response: in Components
November 28, 2011 8:27:15 PM
Will a APEX AL-D500EXP 500W ATX12V Power Supply go into a HP Pavilion p6616f Desktop PC?
More about : apex d500exp 500w atx12v power supply desktop
November 28, 2011 8:37:54 PM
why so?
m
l
November 28, 2011 8:46:52 PM
And when I say will it go into, I really mean, will it fit into place or will it be too big?
m
l
a c 723 ) Power supply
a b α HP
November 28, 2011 9:21:10 PM
It is not a quality unit, does not have active PFC and a low efficiency rating (not 80+certified)!
"Passive PFC uses passive elements such as a ferrite core inductor on the input source to create a countering reactance. While easily applied to the existing power circuitry without much modification, the power factor is low (60 - 80%), the AC input must be chosen (115VAC / 230VAC), and the harmonics produced from the difference between the capacitance and the inductance are hard to control. Significant electromagnetic noise can result.
Active PFC uses switching regulator technology with active elements such as IC, FET and diodes, to create a PFC circuit This circuit has a theoretical power factor of over 95%, reduces total harmonics noticeably, and automatically adjusts for AC input voltage. However, it requires a complex EMI filter and an input source circuit, and is more costly to build."
It will fit your HP!
m
l
