Hello,
Thanks for reading my question...
I have to build for a local college a system that is primarily used for doing scientific computing work - I have written them a clutch of parallel programs that for "usual" sizes is taking approximately 85-90 hours of continuous 100% CPU utilization run.
The current HW is built on mildly overclocked i7 2600K (the ambience is fairly hot) with a CPU cooler (CM 212) with 16GB RAM. Contains a ATI 5770 graphics card.
I am to build a next refresh for them by end of Apr 2012 (end of the current acad session). My options are (open to advice) - either a Sandy Bridge E processor machine on X79 , or a Xeon DP machine (terribly expensive, but sometimes college admins may be turned ..) - Overall budget - $3500-stretchable to $4000.
So, first question - is there a likelihood of having a Dual Processor Sandy bridge E? Are desktop dual processor Chips comparable to Single Processor systems (at constant expenditure)?
Will the lower end Xeon DP be faster for a memory intensive seriously multi-threaded program as compared to a single processor Sandy Bridge E?
And, another one I am trying to sort out - Will a DP system require two Windows 7 Ultimate (retail) Licenses?
Finally, whats a good DP configuration ?
Expected life - 3-4 years
No upgrade of any part is likely in this time frame ..
Thanks...
Thanks...
