Hello,
I acquired a Toshiba Satellite 655D. The entire power button assembly, including the female connector (broken off motherboard) and keyboard strip connector are also broken on the motherboard. I found replacement power button, but not the female housing it connects to on the motherboard. I purchased a replacement keyboard cable connector that is to be reconnected to the motherboard, but it came with a flat multi wired strip that isn't on the original. The original was soldered directly to the motherboard. What are my options?
