Hello All,
okay I'm stuck between going AMD or Intel (seems to be the case these days) I've owned both intel and amd systems, and have liked both platforms. my recent system was a dell xps studio 7100 with 1045t proc and 1gb 5770 that i picked up just to play starcraft. as the time came and past from the BF3 beta, i slowly started upgrading...and since i'm addicted to upgrading i just went berserk. so story short, here is what i have done:
corsair 600T SE (white)
h80 p/p config
2x msi 2gb 6950 xfire, shader unlocked
8gb vengence
2x 60 gb force 3 raid 0
1tb platter
asus m5a88v evo
1045t oc'd 16% 3.13 ghz (tried going for 3.5 but it didn't like that too much)
corsair ax750
now i've done some researching between sandybridge and ivy bridge, and amd 1100t and fx series procs. i know amd is cheaper and doesn't compare to the 2500k or 2600k. this is where i'm basically stuck...like i need someone to push me off the ledge so i can make a decision. i'm torn between getting the i5-2500k (or i7-2600k since its ~$50 more) with either an asrock mobo or asus mobo z68 board (x79 is just too dang expensive right now) and i want it to be ready for ivy bridge when it comes out. the other hand is going amd with the fx 8150 and a 990fx board (asus, msi, gigabyte) what i love about the amd boards is that the pci lanes are 16/16 crossfire, which i know theres like a what 3% increase from 16/4 16/8 and 16/16. (keep in mind i'm only one 24" 1080p currently, planning on scaling it across 3 of those which i know will help with the video cards and performance).
this is strictly a gaming pc as i have my work laptop to do work on, i know games nowadays only use up to 4 cores. the thing is since i'm doing this i might as well go big (not too big) and just be done and ready for the future with ivybridge or piledriver. i know some of you will say wait but dangit money is burning in my pocket and i just want to be done with upgrading for a few months and i want to be very happy with which ever decision i go with. i just need that push to get me there. please state of any bottlenecks that you might see with my current config and going with either amd or intel.
please refrain from posting intel because intel is better, blah blah blah etc etc etc.
h80 p/p config
8gb vengence
1tb platter
asus m5a88v evo
corsair ax750
