Help with nero dvd issue
Been trying everything i know to get this to burn me an iso but i keep getting some kind of error. Latest one is DMA-driver error/CRC error. Please help.
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'E:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 11/2/2004 1:54:32 PM
NT-SPTI used
Nero Version: 7.5.7.0
Internal Version: 7, 5, 7, 0
Recorder: <Memorex 16X-DDL-IN> Version: 1.A3 - HA 1 TA 0 - 7.5.7.0
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <Memorex 16X-DDL-IN >Version: 1.A3 - HA 1 TA 0 - 7.5.7.0
=== Scsi-Device-Map ===
DiskPeripheral : SAMSUNG SV0813H atapi Port 0 ID 0 DMA: On
CdRomPeripheral : Memorex 16X-DDL-IN atapi Port 1 ID 0 DMA: On
=== CDRom-Device-Map ===
Memorex 16X-DDL-IN F: CDRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 73400320 (0) Byte
BUFE : 0
Physical memory : 503MB (515608kB)
Free physical memory: 112MB (115412kB)
Memory in use : 77 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
6.1.2009
Burn DVD Image
11:42:43 PM #1 Text 0 File SCSIPassThrough.cpp, Line 583
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
11:42:44 PM #2 Text 0 File Burncd.cpp, Line 3435
Turn on Disc-At-Once, using DVD media
11:43:21 PM #3 Text 0 File DlgWaitCD.cpp, Line 301
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 2295061 (510:00.61, 4482MB)
11:43:21 PM #4 Text 0 File DlgWaitCD.cpp, Line 313
Write in overburning mode: NO (enabled: CD)
11:43:21 PM #5 Text 0 File DlgWaitCD.cpp, Line 2863
Recorder: Memorex 16X-DDL-IN, Media type: DVD-R
Disc Manufacturer: SONY16 - D1
Disc Application Code: 64, Disc Physical Code: 193
11:43:21 PM #6 Text 0 File DlgWaitCD.cpp, Line 485
>>> Protocol of DlgWaitCD activities: <<<
Insert empty disc for simulation.
(Medium in drive: Unknown. Medium required by compilation: DVD R/RW, DVD R DL.)
11:43:21 PM #7 Text 0 File ThreadedTransferInterface.cpp, Line 820
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (2 - CD-ROM Mode 1)
2 indices, index0 (150) not provided
original disc pos #0 + 2295062 (2295062) = #2295062/510:0.62
not relocatable, disc pos for caching/writing not required/not required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2294912 blocks [Main]
11:43:21 PM #8 Text 0 File ThreadedTransferInterface.cpp, Line 1033
Prepare recorder [Memorex 16X-DDL-IN] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4700286976, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 2295062 | 2294912 | 0x00
0 | 1 | 1 | 0x41 | 2295062 | 2294912 | 0x00
2295062 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
11:43:21 PM #9 Text 0 File SCSIPassThrough.cpp, Line 41
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
11:43:21 PM #10 Phase 24 File dlgbrnst.cpp, Line 1746
Caching of files started
11:43:21 PM #11 Text 0 File Burncd.cpp, Line 4262
Cache writing successful.
11:43:21 PM #12 Phase 25 File dlgbrnst.cpp, Line 1746
Caching of files completed
11:43:21 PM #13 Phase 32 File dlgbrnst.cpp, Line 1746
Simulation started at 2x (2,770 KB/s)
11:43:21 PM #14 Text 0 File ThreadedTransferInterface.cpp, Line 2730
Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
11:43:21 PM #15 Text 0 File DVDR.cpp, Line 3026
Recording mode: Sequential Recording Mode
11:43:21 PM #16 Text 0 File DVDR.cpp, Line 3182
Start write address at LBA 0
DVD high compatibility mode: Yes
11:43:21 PM #17 SPTI -1502 File SCSIPassThrough.cpp, Line 293
F: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1502)
Sense Key: 0x04 (KEY_HARDWARE_ERROR)
Sense Code: 0x08
Sense Qual: 0x03
CDB Data: 0xAC 00 00 00 00 00 00 00 00 64 00 00
Sense Area: 0x70 00 04 00 00 00 00 0A 00 00 00 00 08 03
Buffer x06355400: Len x648
11:43:21 PM #18 Text 0 File Cdrdrv.cpp, Line 9234
---- DVD Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 2.1 (33)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26127F h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Start sector number of the current Border-Out: 2FE10 h
Start sector number of the next Border-In: 2FFA0 h
Media Specific [16..63]:
00 60 00 10 20 30 40 50 - 00 00 00 21 00 00 00 00 .`...0@P...!....
00 02 FE 10 00 02 FF A0 - 00 00 00 00 00 00 00 00 ................
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
11:43:25 PM #19 Text 0 File Cdrdrv.cpp, Line 1290
23:43:25.421 - F: Memorex 16X-DDL-IN : Queue again later
11:44:19 PM #20 SPTI -500 File SCSIPassThrough.cpp, Line 293
F: CdRom0: SCSIStatus(x00) WinError(1117) NeroError(-500)
Sense Key: 0x00 (KEY_NO_SENSE)
Sense Code: 0x00
Sense Qual: 0x00
CDB Data: 0x2A 00 00 00 03 00 00 00 20 00 00 00
Sense Area: 0x00 00 00 00 00 00 00 00 00 00 00 00 00
Buffer x06323800: Len x10000
0xE6 25 BD 53 CA C8 64 9E 49 7D 48 70 34 BA 6B 33
0x64 10 85 16 A1 F2 3B 93 A7 FA 02 35 21 D9 80 29
0xD8 36 3F 65 22 49 0A BC CC A0 18 1B 12 C4 A6 4B
11:44:19 PM #21 SPTI -1114 File SCSIPassThrough.cpp, Line 293
F: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1114)
Sense Key: 0x06 (KEY_UNIT_ATTENTION)
Sense Code: 0x29
Sense Qual: 0x00
Sense Area: 0x70 00 06 00 00 00 00 0A 00 00 00 00 29
Buffer x06357c00: Len x10000
11:44:19 PM #22 CDR -1114 File Writer.cpp, Line 278
Reset occurred
11:44:19 PM #23 Text 0 File DVDR.cpp, Line 3402
EndDAO: Last written address was 767
11:44:20 PM #24 Phase 34 File dlgbrnst.cpp, Line 1746
Simulation failed at 2x (2,770 KB/s)
11:44:20 PM #25 Text 0 File Cdrdrv.cpp, Line 10459
DriveLocker: UnLockVolume completed
11:44:20 PM #26 Text 0 File SCSIPassThrough.cpp, Line 583
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=2560 bytes, created 8/24/2006 7:47:00 PM
File 'Drivers\PXHELP20.SYS': Ver=3.00.33a, size=36528 bytes, created 8/24/2006 7:47:00 PM (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
1 answer Last reply
More about help nero issue
  1. Wrong section. Try reposting here: http://www.tomshardware.com/forum/forum-49-301.html or PM one of the Moderators and they will move it for you.
Site Bug Reports Nero Tom's Hardware
