Confused on Power Supply
  • Power Supplies
  • Components
  • Product
Last response: in Components
November 30, 2011 3:06:42 AM
Tomorrow I have two power supplies coming, a OCZ 700W http://www.newegg.com/Product/Product.aspx?Item=N82E168... and the Rosewill 1000W http://www.newegg.com/Product/Product.aspx?Item=N82E168.... I've heard poor things about both. After dropping all this money I am feeling anxious about these purchases and am wondering what I should do.
Processor-
i7 2600K - $319.99 with a $20 Newegg gift card
http://www.newegg.com/Product/Prod [...] 5884sch43q
Motherboard-
ASUS P8Z68-V PRO - $179.99
http://www.newegg.com/Product/Prod [...] h70lh9lbt1
Processor Fan-
COOLER MASTER V6 GT RR-V6GT-22PK-R1 - $29.99 (after mail-in)
http://www.newegg.com/Product/Prod [...] 3v99ql4pm2
GPU -
Galaxy 58NLH5HS3PXZ GeForce GTX 580 (Fermi) - $439.99 (after mail-in)
http://www.newegg.com/Product/Prod [...] et7k3cgv2g
Sound Card-
Creative Sound Blaster X-Fi Titanium Fatal1ty Professional - $84.99
http://www.newegg.com/Product/Prod [...] 6v2tq925gy
Hard Drives-Crucial m4 128gb SSD
Seagate Barracuda XT 2000 GB 7200RPM - $172.95
http://www.amazon.com/Seagate-Barr [...] k-c1001-20
RAM-
Corsair Memory Vengeance 16 Quad Channel Kit DDR3 1600 MHz - $97.74
http://www.amazon.com/Corsair-Veng [...] k-c1001-20
CD Drives -
2 x LITE-ON DVD Burner - Bulk 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM - $16.99/ea
http://www.newegg.com/Product/Prod [...] 5sf533de1c
What PSU should I use/buy?
Thanks in advance
More about : confused power supply
a c 111 ) Power supply
November 30, 2011 3:17:26 AM
I would go with the rosewill one, because 700w might just cut it, but you want some headroom for oc'ing.
m
l
November 30, 2011 3:23:57 AM
I figured after a moderate overclock I should be around 750-800W max leaving ample headroom with the 1000W. However the bad reviews for the rosewill are BAD and I have serious buyers remorse to include such poor reviews with my new baby.
m
l
a b ) Power supply
November 30, 2011 3:28:14 AM
you are about 300w over even with a OC CPU, 450w at stress (gaming would be lower). the modstream is a solid enough PSU but with low 12v rail power, it will do the job though. Personally i would go with the corsair TX650 if you don't plan to run SLI
Test System Specs
- Intel Core i7 920 (Overclocked @ 3.70GHz)
- x3 2GB G.Skill DDR3 PC3-12800 (CAS 9-9-9-24)
- Asus P6T Deluxe (Intel X58)
- OCZ GameXStream (700W)
m
l
a b ) Power supply
November 30, 2011 3:30:31 AM
what's your budget ? And no you don't need more than a 650W if you won't OC, 700W if you'll OC each nail on your PC, 850W for SLI GTX 580s in future.
m
l
November 30, 2011 3:35:50 AM
I feel this card should be able to hold me over for a good amount of time as it is. Budget, probably less than 150 but I'll spend the money to make sure my investment is safe.
More my internal monologue just wants to build this tomorrow, but not at the risk of a poor PSU powering it all.
m
l
a b ) Power supply
November 30, 2011 3:40:56 AM
Cooler Master Silent Pro Gold 850W
NZXT 850W
Those are ones of the top & the best PSUs around
EDIT: Corsair HX 750W $140 after MIR, even if you SLI in future with the Upcoming GTX 6K/7K series they supposed to use lower power consumption than the current series so you'll be more than good as well
m
l
a b ) Power supply
November 30, 2011 3:51:59 AM
plenty of power, well reviewed, and well under your budget
m
l
a b ) Power supply
November 30, 2011 6:58:54 AM
a good 600watts will see you perfectly for the 1 card detup... sesonic, corsair and others have great offerings.
if you want headroom then add 200watts per potential gfx cards. 250 if your thinking high end nvidia.
m
l
a b ) Power supply
November 30, 2011 5:01:04 PM
ilysaml said:
Except for being Modular!
I don't see the OP requesting a modular unit.
Having built PCs with both modular and non-modular I could care less about the feature (even though one of my current PSUs is modular) since I often end up using one-two less cable with the modular.
m
l
