Yes No
Ads
Tom's Hardware > Forum > CPU & Components > Sound Cards > PC with high end sound card vs receiver?
Forum CPU & Components : Sound Cards PC with high end sound card vs receiver?
So, would a media PC with say an AMD A6 CPU for the integrated graphics + an HT omega Claro (200 dollar soundcard) work well as a home theater system/media access system?
My only concern would be whether or not I could use the sound system with the TV on cable. Basically, I am asking if it is possible to turn a PC into a receiver, and would sound quality take a major hit?
hmm...
Reply to Welve
You'd probably not notice the difference in sound quality. However, if you have an amp, then that would be the better bet. You can output from the HTPC using the HDMI cable, and if the onboard GPU is 5xxx or 6xxx series you can bitstream to the amp also. I'm not sure if a soundcard can do that. Also, if you have an amp for powering the speakers then why use a soundcard when you have the equipment already?
Reply to diellur
I don't have an amp, basically I am asking if I could build a PC that could match a receiver in sound quality, but have all the benefits of a media center, hulu, netflix, blu ray etc, is that possible?
like this kind of receiver: http://www.newegg.com/Product/Prod [...] 6882117395
Reply to Welve
I'd prefer an HTPC over a standalone receiver, to be honest. You can churn amazing quality from a PC as well, and few people have the money to afford valve amps and the accompanying speaker to actually hear the difference between the PC's quality and the receiver's.
Also, the pro of a PC is that you can service it yourself, and you have the option of both internet connectivity and storage of your favourite music/movies in equal quality without the delay of optical drives. Simply rip to image files and load onto a virtual drive reader whenever you're interested and you have Blu Ray quality video and audio with standard ease-of-HDD (or SSD if you have a lot of money) accessibility.
------------------------------ [Intel C2Q Q8400 @ 2.66GHz] [MSI G41P33-TM] [2x2GB Corsair XMS2 DDR2-800] [MSI GeForce GTX460 Cyclone 1GB] [Samsung BX2335 Display]
Reply to Toxxyc
Some soundcards offer ouput quality that is superior to most high end receivers. Heck, some even come with built in amps now.
That being siad, if you want to go the HTPC route, I'd recommend taking a look at the Auzentech Home Theatre HD, as the HDMI In/Out solves a LOT of connectivity problems...
Reply to gamerk316
So, strictly from a sound stand point now: if I get that card the Auzentech, I wouldn't need to buy a receiver like the one I linked?
My performance will match or exceed that? I want a good surround sound system primarily, but they cost enough that I feel I could make a pretty good HTPC for around the same price.
Reply to Welve
Heres a very good reveiew of the HTHD:
http://www.guru3d.com/article/auze [...] rd-review/
The HTHD is basically the closest thing you can get to a receiver on a PC.
Reply to gamerk316
There are 1866 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
CPU fan
By mocchan, 1 hour ago:
Your case has a cut out for a backplate to be installed, so you SHOULD be fine installing...
Best offers
Top experts
