Symptoms: I hit the "go" button, all fans start to spin up for about 1 second then power off. If I hit the Q_Reset button the same thing happens. BUT, SOMETIMES, the system will boot and when it boots, it will run for days.
Here's my setup:
Thermaltake V1000 (2000?) aluminum case
R3E / 950 / 12 gig crucial DDR3 1600 (3 4gb pieces)
EVGA GTX 460 Video.
Thermaltake 1200 W ps
Power connectors: Main ATX , plus 2 more 8 pin connectors on mobo near fan, plus 4 pin just north of 1st slot - the only one that's not connected is the one at the extreme bottom of the board.
I'm using a 256 gig Crucial SSD and a
BD/DVD Reader/Writer.
So, I thought this was a mobo problem so I RMA'd it, just put in 2nd one and SAME THING?!
I tried running 2 or 1 piece of ram - same thing.
What's left to try?
Well, I was thinking of:
1) CMOS Reset
2) Pulling the video card (yea - I know - but the system DOES boot and stays up!)
3) changing the LN-2 Mode Jumper to activate it
Is there anything else I can try? Sure, I could Breadboard it but I doubt that this will change because the system DOES run (Windows 7). I installed the OS, ran through all the upgrades and did a ton of work with it up.
One more thing - when it does come up it asks me if I want to hit F1 (setup) or F2 (load defaults and go) - I hit F2 because after going into setup, it saves, restarts, powers down then it's dead again.
Here's my setup:
EVGA GTX 460 Video.
What's left to try?
1) CMOS Reset
