Archived from groups: alt.cellular.bluetooth (More info?)
SNIP
> Both devices see each other. The problem is when doing a sync over
> bluetooth
> 1. syn initiated (stage 1)
> 2. after 30 or so seconds TT gives message:
> "connection between hand held and desktop could not be established.
> Please check your setup & try again".
> This is really weird as paring was successful so why doesn't sync
> work?
You need to have the T|T configured properly for synching as opposed to
using BT for say a Network or Cell Phone connection.
I created a new Connection type through Preferences that I called BT to PC.
The parameters are
Connect To: PC
Via: Bluetooth
Device: <PC device name as discovered by Bluetooth>
This works perfectly for me. So check which connection type you are using,
it should say so in the Hot Sync app.
"Tony Clark" <curiousgeorge1964@hotmail.com> wrote in message
news:vXhgc.14399$A_4.10734@newsread1.news.pas.earthlink.net...
> SNIP
> > bluetooth
> > work?
PC.
> The parameters are
> Connect To: PC
> Via: Bluetooth
> Hope this helps
> TC
