Hi, I currently have a asus p5wd2 premium http://uk.asus.com/Motherboards/Intel_Socket_775/P5WD2_Premium/#specifications motherboard and I am not looking for an upgrade for that because it's expensive. The main reason I'm here is because I want to know my choice in parts will be stable and compatible:
Cooler Master Hyper 212 Evo
Asus nVIDIA 3D GeForce GTX 550 TI
G.Skill Ripjaws - Memory - 8 GB : 2 x 4 GB - DIMM 240-pin - DDR3
Arctic Cooling MX-2 4g High Performance Thermal Compound
Alpine 650W Quiet Silent PC Power Supply PSU 120mm Fan
Also if you have any suggestions on what else I should buy instead I will be very grateful. Also I am looking to run games such as Minecraft, Battlefield 3, Arma II DayZ.
Thank You.
Thank You.
