L lca1443 Distinguished Nov 1, 2011 30 0 18,530 Dec 1, 2011 #1 So last night I built my htpc, everything is working fine (as far as I can tell). Couple questoins: My temps are around 40c I assume this is fine? I am using the stock cooler, I assume that the stock paste that was already on is sufficient?
ulillillia Distinguished Jul 10, 2011 551 0 19,010 Dec 1, 2011 #2 You shouldn't be worried about your temps until they start going above 70C. Is that 40C under load? I'm too uncertain with your second question to reliable answer it. I would think it is sufficient though but don't trust 60% certainty much. Upvote 0 Downvote
L lca1443 Distinguished Nov 1, 2011 30 0 18,530 Dec 1, 2011 #3 I'm 99% sure its fine, I just worry about things. Upvote 0 Downvote
