Archived from groups: microsoft.public.windowsxp.customize (More info?)
What does this mean. If I understood what you are trying to say, maybe I
could help you.
"But late time got no, I have enable all activeX setting in IE also the
same."
"Leong" <leong_oh@hotmail.com> wrote in message
news$hjx4tZEHA.3988@tk2msftngp13.phx.gbl...
> I don't know why lately my IE got this type of problem, when I go some
> website it often pop up this message,
> "Your current security setting prohibit ActiveX controls on this page. As
a
> result, the page may not display correctly."
same.
> Blake
Try re-registering the following .dll files
Softpub.dll
Wintrust.dll
Initpki.dll
Urlmon.dll
1. Click Start >Run and type
regsvr32 Softpub.dll
Click okay to register it
You should get a dialog box telling you that it was successful.
2. Repeat the process for the other .dll files.
3. Restart your computer and try the update site again.
if the above doesn't help -
http://www.jsiinc.com/SUBD/tip1500/rh1525.htm Your security settings prohibit running ActiveX controls on this page.
http://www.virtualmachine.tk/ Note: Versions 5.00.3809 & 5.00.3810 are Security Fixes for version 5.00.3805.
Download and Install version 5.00.3805 (full version) first before installing
the upgrade(s).
Run the installation check which is available on the side of the page.
Sun version:
http://java.sun.com/getjava/index.html
> "Your current security setting prohibit ActiveX controls on this page. As a
> But late time got no, I have enable all activeX setting in IE also the same.
> Blake
Leong,
You should set either your time or time zone correctly, you are posting in
the future.
Sir_George
a
same.
> Blake
Here's a tip for all of you who may have been getting the following
message:
"Your current settings prohibit running ActiveX controls on this page.
As a result, the page may not display correctly."
I found that it was caused by the "DCOMbobulator" application
available from Steve Gibson at http://grc.com/
That may be a handy app to provide security but it will cause that
error message to be displayed. Took me a while to figure out, so I
hope this will help some others who may have installed it and
forgotten about it.
