Wireless network Adapter Problem
Last response: in Wireless Networking
January 29, 2011 9:58:39 AM
Hi there recently my belkin wireless adapter is playing up. It can detect and connect to my network but when attempting to use the internet it will say no connection. I have made sure windows zero config is started as well as on automatic but still the same.
At first it might be a firewall problem i disabled the firewall still to no avail. The belkin wireless utility will not detect any networks while the windows utility can.
any help would be appreciated.
More info:
router - netgear dg834g
adapter - belkin wireless adapter F5D9050
os- win xp
Anonymous
January 29, 2011 11:08:08 AM
Don't try to run both utilities at once -- just Windows or just the Belkin one.
Also check TCP/IP Properties.
Start, Connect To, Connection, Properties, Scroll Down TCP/IP and highlight, click Properties and check that Obtain DNS and IP address automatically are enabled.
January 29, 2011 11:55:34 AM
My bad i didnt explain, i am not running both at once.
I will check the tcp/ip properties
thanks for the help
