First Build, Need Help/Opinions
bobthebaptist
19
Approximate Purchase Date: this month or next month
Budget Range: ~1500$
System Usage from Most to Least Important: Battlefield 3, Skyrim, Rage,general gaming, web browsing, etc
Parts Not Required: mouse and keyboard, os
Preferred Website(s) for Parts: Newegg.ca
Country of Origin: Canada
Parts Preferences: none
Overclocking: maybe
[strike]SLI or[/strike] Crossfire: yes, eventually
Monitor Resolution: not sure, could someone tell me ?: http://www.newegg.ca/Product/Product.aspx?Item=N82E16824236052
Hey guys, I will be building a new computer pretty soon and I'd appreciate some advice as my knowledge about gaming pcs is not the greatest. First of all, I will post the parts I want to buy. I'd also like to know if there are better alternatives or any incompatibilities with some parts. As for the asssembling, I'll be fine since ive done it a couple times.
Parts
Monitor:
Tower:
http://www.newegg.ca/Product/Product.aspx?Item=N82E16811119213
PSU: (750 watts enough for crossfire?)
http://www.newegg.ca/Product/Product.aspx?Item=N82E16817139010
MOBO:
http://www.newegg.ca/Product/Product.aspx?Item=N82E16813131646&Tpk=asus%20m4a88td-v%20evo%2fusb3
Ram:
http://www.newegg.ca/Product/Product.aspx?Item=N82E16820231352
Processor: (Overkill?)
http://www.newegg.ca/Product/Product.aspx?Item=N82E16819115070
Graphics Card: (will crossfire eventually. Does the company make a difference or are they all the same? ie: xfx, power color, asus, msi, gigabyte if not witch is best)
http://www.newegg.ca/Product/Product.aspx?Item=N82E16814121430
DVD drive:
http://www.newegg.ca/Product/Product.aspx?Item=N82E16827135204
HDD: (Better,more reliable alternatives?)
http://www.newegg.ca/Product/Product.aspx?Item=N82E16822136073
Price total: app. 1400-1500$
Can I green light it or am I missing parts/incompatibilities with my build? I more than welcome you guys to suggest me better alternatives, thanks. :)
AdrianPerry
Ok a few things:
Motherboard - The motherboard you listed is for a socket AM3 processor (AMD CPU), if you want the i7-2600k or other SandyBridge processor, YOU NEED SOCKET 1155.
GPU - 6970, great choice. Brand doesn't make too much difference, sometimes cards are clocked a little higher than reference or offer better cooling or longer warranty. XFX and Sapphire i believe are popular manufacturer choices for ATI cards.
PSU - 850w Recommend for Crossfire 6970's
HDD - Samsung SpinPoint F3 is generally considered the best value 1TB HDD.
CPU - You wont lose any noticeable gaming performance choosing the i5-2500k over the i7-2600k. Unless your doing lots of video coding/rendering, the i5-2500k will be fine.
