Solved
Please help with connection problems
I have a Belkin Play N600 router dual band 2.4 and 5 ghz model number F7D8302 v1. I have tried to talk to "technical support" and I can't any decent help from them. I am not computer illiterate and they don't tell me anything I haven't already tried. And when I tell them the issue they can't figure it out.
The problem I am having is: anytime I turn on my desktop which is hardwired into the Belkin which is wired into the modem I can't connect my Wii or any other wireless devices such as a lap top. They can see the router it just won't allow them to connect to it. This is more of an annoyance than anything but if I want to watch NetFlix while my wife is on the comp I can't do it. When the desktop is off all wireless devices connect just fine.
I was hoping that someone out there in the tom's hardware community had more of a clue than the Belkin "technical support" :pfff: which is a joke and I will never buy another Belkin because of this reason.
Please help and thanks in advance for the reply!
4 answers Last reply Best Answer
More about please connection problems
  1. Best answer
    Sounds like an IP clash. Make sure nothing is on a fixed IP address so that the router can assgn addresses.
    On the desktop check TCP/IP Properties.
    Start, Connect To, Connection, Properties, Scroll Down TCP/IP and highlight, click Properties and check that Obtain DNS and IP address automatically are enabled.
  2. Quote:
    OK sorry it took me a while to get back to this but medic school has put this on the back burner. If you are talking about the start menu I can't find connect to options. I'm still unclear as to how to check the TCP/IP settings. I know the router itself used dynamic addresses. Sorry for the nub question.
  3. Go to Control Panel, Network Connections.
  4. Best answer selected by infirmumdeum.
Configuration Connection Belkin Wireless Networking
