Help with choosing graphics card on new build
Graphics card Master
If you're not editing video, get a 2500K. Heres a combo if you don't too intensive gaming: http://www.newegg.com/Product/ComboBundleDetails.aspx?I...
Though for something more, heres one with a GTX560Ti, should max out 1080p for the most part.
2500K +Z68 $320
http://www.newegg.com/Product/ComboDealDetails.aspx?Ite...
4GB RAM $33.99
GTX 560 Ti $230
Samsung F3 1TB $60
http://www.amazon.com/Samsung-Spinpoint-3-5-Inch-Intern...
Antec 620W $60
V3 case $39.99
Total: $750 before rebates.
You can get a nice 6950 with a nice cooler for ~$30 more.
*edit* Thanks for the reply, btw :) .
How much do you think I would notice the 6950 vs what you have on there?
Would it be worth it? I mean, it's only $30...
I'm assuming you'd recommend your custom build over the pre-built combo from NewEgg?
the 6950 would only be a 5% better in average, but more if you crossfire. It is an Asus model with a nice cooler, so noise and temps should be better.
What games do you play though?
Related ressources
WoW, Starcraft, primarily.
I'm looking to play some decent games, not like Crysis.
Do I need any cooling units?
Sorry for all the questions, this will just be my first custom built unit.
Ask the community
