Yes No
Ads
Tom's Hardware > Forum > CPU & Components > Power Supplies, Cases & Mods > Antec 1200 v3 front audio jack problems
Forum CPU & Components : Power Supplies, Cases & Mods Antec 1200 v3 front audio jack problems
Hola. Whenever I plug something into the front audio jack on my new case the plug pops right back out, I was wondering if this is a case issue or if I forgot to do something.
Reply to Cedande
Have you been trying to plug a 2.5mm plug into a 3.5mm socket?
Reply to ko888
I used two diffrent types of headphones on it and neither of them worked, their both a 3.5mm plug.
Reply to Cedande
If the plug is the standard 1.42cm in depth then the socket is defective. Contact Antec and get it resolved.
Message edited by ko888 on 12-03-2011 at 06:23:44 AM
Reply to ko888
There are 1832 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
CPU fan
By mocchan, 1 hour ago:
Your case has a cut out for a backplate to be installed, so you SHOULD be fine installing...
Best offers
Top experts
