Sign-in / Sign-up
Solved
[Help] Building a computer
  • Homebuilt
  • Computer
  • Systems
Last response: in Systems
September 3, 2011 5:54:39 PM
Hello every one :hello: , I'm building a new computer (gaming rig) and I wanted to know if a Intel core 2 quad Q9300 2.5ghz will really bottleneck a EVGA GTX 460 SE 1gb gddr5. I will also buy a MOBO gigabyte P45T-ES3G with 4gb-8gb ram and a Neo Eco 520c PSU. Thanks alot :)
More about : building computer
a b B Homebuilt system
September 3, 2011 8:54:57 PM
the core 2 is an old CPU, if you are building a new computer, I would recommend you getting the 2nd gen i3/i5 or the AMD Phenom line. If you can wait, you can even go for the upcoming Ivy bridge CPUs from Intel or cheaper FX CPU's from AMD
m
l
September 10, 2011 3:52:45 PM
No I already own a Q9300, but can you tell me if its gonna B-neck a GTX 560 non-ti gigabyte. Yes a GTX 560. If it does, will it be like REALLY b-necked, like I couldn't get a playable frame rate in any game or would it be barely noticible. I want to play MW3 BF3 Diablo3 (yeh that alot of 3s) Skyrim etc maybe not maxed out but on pretty high res. on my 42'' monitor (HDTV) 720p Samsung.
Thanks ! :)
m
l
September 10, 2011 4:51:41 PM
I don't think the gtx 560 will bottleneck the CPU at all
m
l
September 10, 2011 5:48:28 PM
I want to know the opposite actually. Will my CPU bottleneck my GPU ?
Sorry if it's the same answer xD
m
l
Best solution
September 10, 2011 5:54:17 PM
I don't think any bottlenecking will happen
a c 91 B Homebuilt system
September 10, 2011 6:11:56 PM
You want a 460 SE? That's worse than the 6790 and 5770 but costs more by about $30-$40.
The latter you mention, the 560 GTX would be a much better choice.
m
l
September 10, 2011 6:14:27 PM
I think he mis-typed since he typed a 560 non TI in the 3rd post
m
l
September 10, 2011 6:18:55 PM
... Wait? The 560 non Ti is still good. I agree with that card.
m
l
September 10, 2011 6:20:25 PM
Ye, the 560 TI or not is a good card. I dont think the CPU will bottleneck the gfx card tho.
m
l
September 10, 2011 8:27:38 PM
Awsome, well I'll order it soon! By the way, if my tv is called a 720p screen, does it means that if I plug it with an HDMI cable, the max res I'm gonna get is 1280×720 (wich is fine for me, I don't mind not having a ginormous resolution)
Thank you alot for your time !!! :D
m
l
September 11, 2011 2:07:32 AM
Yes, the max res is 1280 x 720 if the monitor res is that. The more pixels (higher the number res) the better the quality of the gaming/movies/whatever.
m
l
September 18, 2011 2:05:01 PM
Best answer selected by yasio.
m
l
