A friend is giving me his old pc but I need to buy a new graphics card for it. My main intention for this computer is to game with it.
The specs are as follows:
Processor - Intel Core 2 Duo E8400 Wolfdale 3.0GHz LGA 775 65W Dual-Core Processor BX80570E8400
RAM - CORSAIR XMS2 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model TWIN2X4096-6400C5
Motherboard - EVGA 123-YW-E175-A1 LGA 775 NVIDIA nForce 750i SLI FTW ATX Intel Motherboard
PSU - hec Zephyr MX 750 750W Peak Output ATX12V V2.3 / EPS12V V2.91 SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Power
Monitor - Viewsonic VX2450WM-LED 24-Inch (23.6-Inch Vis) Widescreen LED Monitor with Full HD 1080p
So far I have been told this GTX 460 is a good choice but I'm not sure I want to spend that much. http://www.newegg.com/Product/Product.aspx?Item=N82E16814130568&cm_re=evga_460_gtx-_-14-130-568-_-Product
This 6670 was suggested as a cheaper option. http://www.newegg.com/Product/Product.aspx?Item=N82E16814150545
I'm looking for your opinions on these cards or different suggestions.
